There are key-ins for Rotate and Rotate Copy, but neither of them have the option of setting the tool to rotate by 3 points. If the key-in is used, the tool always defaults to rotate by active angle. I use rotate by 3 points more than I use rotate by active angle. Is there a key-in that can set the rotate tool to 3 points? I'm actually needing to use the key-in because I want to create separate tool buttons for Rotate and Rotate Copy but want it to be set on the 3 points option by default. Can this be done?
I'm using version 10, update 6.
Does this keyin help
rotate points original
rotate points copy
Carl Myhill
Technical Support Engineer
Bentley Systems
Yes, that works. It was right there, I don't know how I missed it. Thanks!
