I am having trouble with tool icons in my custom tool bar showing one thing and then a different tool is activated when I click on the icon.
Please see the video link below to see my work flow:
https://www.youtube.com/watch?v=CPyXkmxfnm4
I am currently using the Connect trial.
Any help is appreciated.
Josh
After testing it appears that when added to a custom task some tools are remapped to completely unrelated commands.
I will file defect to address the issue.
As a workaround for items doing this you can create a custom toolbox and tools that are mapped to the appropriate commands and then add the needed tools to the custom task.
Answer Verified By: Josh WHEALY
Hi David,
The tools are still bugged in U2.
I just wanted to reply to your answer again and confirm that what you suggested has worked.
