I am currently setting up some standard information and was setting up the sheet index but kept coming across "the selected file does not belong to the active workset". Having read through the forums and tried various fixes like "file associateworkset" with no sucess, I have managed to tie the problem down to the config variable _USTN_WORKSETDGNS pointing to one directory and the files not being in this directory. If i move a file to this directory and add to the sheet index everything works okay, i can even move it back to the required directory and the sheet index will still open the correct file even after restarting microstation. Is there anyway to allow individual files to be in seperate directories.
This only seems to be an issue when you are creating new files from "File New" and selecting your required seed file, maybe this is not the way to do it now. If I have a file and add a model to that file it has the ability to add to index, which is not availble for "File New", but this means I have to create my file and then add a model to allow it to be indexed.
Many thanks for your help
Mark
currently using microstation connect update7 on windows10
Hi Mark,
I have not checked this one out yet, but try adding the folders that you want to be included in the sheet index to MS_RFDIR.
Generally sheets are added to the index via the Callout tools > Create Drawing dialog > 'Add to Sheet Index' toggle.
Marc
has anyone actually found an answer to this question? Nothing suggested works in the FDOT Connect environment. Sheet model is definitely associated with the Workset.
I'm still looking for an answer to this myself, but I wanted to let you know FDOT has it's own community here where you're talking directly with them and other FDOT users. Someone there may have an answer since it's client specific.
OpenRoads Designer CE 2021 Release 2, Version 10.10.21.4
ProjectWise Explorer CONNECT Edition, Version 10.00.03.453
ProjectWise Administrator CONNECT Edition 10.00.03.434
ProjectWise Drive, Version 2023.2.256
