I have learned that using the -debug switch on a shortcut load the last workspace used. This is actually a PowerInRoads installation, but this is a MicroStation issue.
The workspace I am trying to generate an msdebug.txt file for, appears to load and run without issue. But if I run my shortcut which only adds the -debug to the Target field and which works with every other workspace I have tested so far, opens the command window but is the middle of a CFG file that is loading dgnlib's stops in mid line. After a few seconds, the MicroStation has Stopped Working dialog and after it is dismissed, the Program Notification error dialog box opens with its Abort, Retry and Ignore buttons. No matter which you press, the command window closes and an incomplete msdebug.txt is created.
When I use the term workspace, it is primarily the set of files loaded when a certain PCF file is loaded with a pretty generic local workspace otherwise. The workspace is a slightly modified version of the AEC Release 6 workspace from the Tri-Services CADD/GIS Technology Center.
It might be worth posting what the full command line looks like when you're performing this -debug as I should not expect this to crash, even though it is Power InRoads rather than MicroStation.
If an -msdebug stops processing before completion it generally indicates that something is seriously invalid in the configuration so msdebug is unable to proceed any further.
I suggest that you investigate using Bentley Configuration Explorer (BCE) it can be downloaded from the Bentley iWare site, this will give you more visibility of what is going on during startup.
Marc
But the same workspace runs without problems if I do not use the -debug switch. When I gave had bad CFG files in the past, it would open a command window and complain about the error or hang. This only hangs during a -debug run.
