I am trying to edit and amend the configuration variable MS_GUIDGNLIBLIST to reference a personal .dgnlib with a custom tool bar. However, I am unable to modify this variable as all of the options (Add new variable, modify selected variable, etc..) are "grayed out" and non-selectable. Is there a way to have those options selectable? One side note, I am running microstation in a program called "ProjectWise". Thank you.
Unknown said:I am running microstation in a program called "ProjectWise"
ProjectWise (PW) is a document management system (DMS) that restricts what you, as a user, can do with a document and your MicroStation configuration. It looks like your PW administrators have set things up so that you can't footle with that configuration variable.
There is a Content Management Forum that deals with PW questions.
