I have a file when i do any work in it i get an error message pop up, see below. I have been told it could be due my configuration file pointing to the wrong place for some system files. I am happy to amended the config file but can anyone tell me which section i need to amend.
many thanks for your help
Mark
Unable to display results because an error occurred while processing the query.
User Supplied Message: Unable to display results because an error occurred while processing the query.
A ClosedRepositoryException was thrown: Bentley.ECSystem.Repository.ClosedRepositoryException: Exception of type 'Bentley.ECSystem.Repository.ClosedRepositoryException' was thrown.
at Bentley.RuleDrivenPresentationECPlugin.SchemaHelperInternal.IsConnectionSupported(RepositoryConnection connection)
at Bentley.RuleDrivenPresentationECPlugin.RuleDrivenContentProvider.UpdateContents(RepositoryConnection connection, IList`1 updatedContentProviderPageableContainers, Int32& totalNumberOfElementsInUpdatedContainer, ContentGroup contentGroup, IAUISelectionControl selectionControl, Int32 pageSize, IDictionary`2 instanceChangeRecords, IDictionary`2 relationshipChangeRecords, IExtendedParameters extendedParameters)
at Bentley.EC.Presentation.Content.ContentServiceInProcess.UpdateContents(RepositoryConnection connection, ContentServicePageableContainer& updatedContentServicePageableContainer, ContentGroup contentGroup, IAUISelectionControl selectionControl, Int32 pageSize, IDictionary`2 instanceChangeRecords, IDictionary`2 relationshipChangeRecords, IExtendedParameters extendedParameters)
at Bentley.EC.Controls.ContentServiceContentModelAdapter.UpdateModel(ContentServicePageableContainer& updatedContainer, IDictionary`2 instanceChangeRecords, IDictionary`2 relationshipChangeRecords)
FROM - (Bentley.RuleDrivenPresentationECPlugin.SchemaHelperInternal, Bentley.RuleDrivenPresentationECPlugin, Version=1.0.0.0, Culture=neutral, PublicKeyToken=4bf6c96a266e58d4)
DLL - D:\Bentley\MicroStation CONNECT Edition\MicroStation\Assemblies\ECFramework\extensions\Bentley.RuleDrivenPresentationECPlugin.dll
Caught by (Bentley.EC.Controls.ContentServiceContentModelAdapter, Bentley.EC.Controls3, Version=1.0.0.0, Culture=neutral, PublicKeyToken=4bf6c96a266e58d4)
METHOD - Bentley.EC.Presentation.Content.ContentUpdateStatus UpdateModel(Bentley.EC.Presentation.Content.ContentServicePageableContainer ByRef, System.Collections.Generic.IDictionary`2[Bentley.ECObjects.Instance.IECKey,Bentley.EC.Persistence.InstanceChangeRecord], System.Collections.Generic.IDictionary`2[Bentley.ECObjects.Instance.IECKey,Bentley.EC.Persistence.RelationshipChangeRecord])
DLL - D:\Bentley\MicroStation CONNECT Edition\MicroStation\Assemblies\ECFramework\Bentley.EC.Controls3.dll
Caught:
at Bentley.EC.Controls.ContentModelObserver.UpdateModel(IDictionary`2 instanceChangeRecords, IDictionary`2 relationshipChangeRecords)
at Bentley.EC.Controls.ContentControl.ListGridContentPanel.OnUpdate(IDictionary`2 instanceChangeRecords, IDictionary`2 relationshipChangeRecords, ContentUpdateStatus& updateStatus)
at Bentley.EC.Controls.ContentControl.ContentPanel.ContentControlUpdateEventHandler(Object sender, EventArgs e)
at System.Windows.Forms.Timer.OnTick(EventArgs e)
at System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
at wWinMainCRTStartup()
Sorry forgot to put version
Using Microstation Connect update 7 10.07.00.39
Hi Mark,
Please can you tell us what you have modified in your configuration?
One of the lines above mentions:"D:\Bentley\MicroStation CONNECT Edition\MicroStation\Assemblies\ECFramework\extensions\Bentley.RuleDrivenPresentationECPlugin.dll"
Where have you installed MicroStation on the C or D drive?
Marc
File attached.
All software is load onto d drive so connect would be loaded in D:\Bentley\MicroStation CONNECT Edition\
<<file removed by moderator>>
Hi Mark
I don't think this is the cause of the problem, I will give you a call to resolve it with you.
Stephen
