In MicroStation V8i I was able to prevent showing levels from a DrawingSeed.dgnlib in LevelManager/LevelDisplay using the variable MS_LEVELS_EXCLUDELIBS.
In MicroStation CONNECT Edition this variable don't work. It seems that this variable is no longer exists in CONNECT.
Is there an other variable or possibility in CONNECT?
Thanks for any help!
Christian
MS_LEVEL_LIB_DIR may be what you are looking for.
Timothy Hickman
Main: 877 627 3772|
Have tried this variable but it don't work.
Have had a look into the online help. There is written:
Defines the default directory to look for when exporting levels or importing levels to/from a CSV, DGN, or DGNLib file.
But thanks for your reply.
Would a Level Filter fit your need?
You can place the Level Filter(s) in the DgnLib.
I Hope This Helps Someone Reading This! (Intergraph>PseudoStation>MicroStation user since 1980's)
I know, this would work, but we use several Level.dgnlibs for MicroStation and also for AECOsim.
It means to create and use several Level Filter is much more uncomfortable compared to exclude always the same levels.
Therefore this variable was very helpful.
Hi Christian,
We have filed Defect 796662 to track this issue. I will follow up with you via SR.
Maria
Maria Garcia
Answer Verified By: Christian Mittermeier
