In preparation to eventually be able to start using CONNECT products I'm still trying to better understand the workspace setup of these. I will have users of both PowerDraft CONNECT and OpenRoads Designer. With what info I have found these two don't seem to play well together. I have setup a network location for all the company and client standards. I would like for both products to see the same location for company standards, but I would like to be able to separate the civil files like Feature DGN libraries so that only OpenRoads Designer can see them. I can't seem to figure out how to do that right now PD is finding all the civil files that it doesn't need to see along with the company standard files.
Here are the Config Explorer files for the same workspace for each program if that helps.
ConfigEX.zip
