Hello
I'm adjusting the ribbon in microstation connect and would like to make my own attributes and primary groups, and not use the preset ones. The problem then is the shortcuts. Because in preferences - position mapping I have attributes & primary positions as default; A & S, but when I make my own Attributes and primary group they are treated just like any other group. That means that the shortcuts gets kind of messed up when I have/dont have those groups in different tabs. I want my own to be treated just like the attributes or primary group should be, but customize it myself. Is there a way to do this?
Robert
Unknown said:Old Position Mapping is also typically 2 or 3 key-ins combination, so Q + something (+ something) is pretty the same (and does not depend on a tool position)
I think my biggest problem is I really don't want it to be 3 key-ins. Therefore I can't put that many tools under Q and space bar as you suggest.
Unknown said:I think my biggest problem is I really don't want it to be 3 key-ins.
But it's general problem, not the difference between keyboard shortcuts and Position Mapping, isn't it?
Unknown said:Therefore I can't put that many tools under Q and space bar as you suggest.
So use another key. I know the most of them are assigned by default to another functionality, but experience of many of my customers is they don't use them all, so they reorganized default assignment to free some key shortcuts.
Often used aproach is they assign the most important tools to <Space> (which is fully configurable), some from them also assigned selected key to open specified group (no more key press is required, because the tool is selected by mouse), and the other tool groups are assigned at second level, so it's about to change default schema under Q.
Maybe the first question is how many groups (or tools directly?) you want (and really need) to assign to be accessible through keyboard shortcuts.
It's just an idea that I have not tested, so not sure whether it works, but maybe visibility check can be used there also, so for the same shortcut a group with context dependet content will be displayed.
With regards,
Jan
Unknown said:But it's general problem, not the difference between keyboard shortcuts and Position Mapping, isn't it?
Yes, that's true.
Unknown said:So use another key.
What we had before was numbers for those main tasks I talked about, (don't know if main tasks is something really common, our just something only my company uses). But numbers are not configurable as shortcuts.
Anyway, thanks for all your input Jan, I'm gonna have to think about how to make this as easy as possible for all our employees. Just find it too bad numbers can't be used as we used to use them.
Unknown said:But numbers are not configurable as shortcuts.
Yes, they cannot be used at first level ... not quite sure why.
In fact I was not aware of this limitation for quite long time in the past, because Czech keyboard has local characaters instead of numbers (which are accessible using Shift), so "first keyboad row" can be used when swtiched from English keyboard.
Unknown said:Just find it too bad numbers can't be used as we used to use them.
In understand this is bad issue when you use them in the past. I don't know too many users that modified Main Task, typically they use other tasks for customization, so they have not depended on numbers.
To get the shortcuts to the Main toolbar as they were available out of the box you have to use the Task Navigation workflow.
However if you pin the Main group to all workflows the shortcuts will be available in any of your custom workflows. See below:
Note that the Main group is pinned.
To keep the "S" key associate to the primary tools try the following:
If you are having issues with the Position mapped keys please make sure that the dialog with focus is in the "Home" position
