Is there a way to have shortcuts using numbers as in the previous versions of Microstation? without setting them one by one..
Go to the Task Navigation Workflow and pin the Main Group to all workflows the number keys will then be able to be used as in previous versions.
You do have to have position mapping enabled for this to work as well.
It worked! thank you so much!!
