I would like to know if development of Bentley plugin will contionue for Revit 2018, or what is the plan for development in Revit for next versions. I was using Bentley for export (producing i-models) to (i.dgn) in Revit 2017.
Thank you in advance for an answer.
Dominik Krajíček
I am assuming you are talking about the i-model plugin for Revit. It appears that the current version is for the 2016-17 version of products. I would think that this would continue to be developed along with change to the Revit software as well as Bentley products.
https://www.bentley.com/en/products/product-line/building-design-software/i-model-plugin-for-revit
HI Andrew,Can you confirm if we have any Revit plugin to import in LumenRT.In Softwaredownloads not able to find ,Can you please into this part.RegardsAshutosh Patil
I don't know the answer to this, please can you post this question in the Visualization Forum
Marc
