I recently switched to Microstation SS4 and am having some issues with the preferences saving.
Upon start up of the program, it will default to the "examples" user every time no matter which user was used last. It will also only save Microstation preferences (ie mouse configuration, dual screens, or auto table settings) when working under the "examples" user. This is an issue because I need to set up a personal user and have the local DOT as the project. When I am in a created user .ucf with the DOT set as my project, it will not save any Microstation settings. Upon closing Microstation, the date modified will update on the .ucf file I have created, but the next time I enter Microstation, all of the settings I configured will be lost.
I have tried deleting the "examples.ucf" and force it to start up with the user created .ucf, but it gives an coding error and will not start up Microstation until I restore the "Examples.ucf".
Is there any way I can set my Microstation up to start up and save preferences with the .ucf file of my choice. The "examples" user has no value to me because it does not have any of the DOT configurations which I work in exclusively.
Brandon
how do you launch MicroStation ? (IE: with a desktop icon) Where is the custom workspace located ? (IE:local machine, network, etc...)
Timothy Hickman
Main: 877 627 3772|
I launch it using a desktop icon. It is currently running on a local machine, but I have also tried using the company network without any luck.
right mouse click on the icon and go to properties. Look at the target. Are there any addition switches added after the ustation.exe ?
Here is the path in the target field.
"C:\Program Files (x86)\Bentley\MicroStation V8i (SELECTseries)\MicroStation\ustation.exe" -wsLoad_GEOPAK_SS4=1
did you create the user and project thru the MicroStation manager ? or was this done some other way ? and when at the MicroStation manager, are these choices available to you, it is just that they are not held/remembered the next time you start the product ?
