I'm unable to edit or add icons to custom tools
I get the following Error:
"InvalidArgument=Value of '7' is not valid for 'SelectedIndex'. Parameter name: SelectedIndex" occurs when attempting to pick icon to add to tool using Workspace>Customize utility.
I found the following solution on the Microstation Wiki, but the solution did not work.
Go to location defined by MS_USERPREF variable. Check for duplicate copies of preference file customize.xml. If no duplicates exist removed the customize.xml file. This creates a new customize.xml using Workspace>Customize interface.
I cannot find a customize.xml file or any file like that. I've experimented with deleting (after backing up) various .xml file in prefs folder - as defined by my MS_USERPREF variable. Nothing has worked and I'm out of ideas. Any help would be greatly appreciated.
Details:
Windows 7
Microstation v8i SS4
version: 08.11.09.832
Adam
Rather than deleting the various *.xml files, you could backup the folder and then restore defaults,
https://communities.bentley.com/products/microstation/w/microstation__wiki/8671/restore-microstation-to-factory-defaults
Carl Myhill
Technical Support Engineer
Bentley Systems
Answer Verified By: Adam Buck
Many many thanks Carl!!!
restore defaults did the trick.
