Hello Everyone,
I have a couple of questions:
Thanks for any help.
David Sullivan
GDOT
David Sullivan said:Can I use the CONNECT version of Configuration Explorer to view V8i configu
No. The way cfg files are processed are different so the CONNECT Edition of the Configuration Explorer is not compatible with V8i.
The V8i version of the Configuration Explorer has been archived. You can use the following temporary link to download the V8i version:
https://bentley.sharefile.com/d-sc88a1c1379448398
Please be aware that the V8i version was last updated in 2012 and is as is.
Answer Verified By: David Sullivan
Just to note if you haven't located it, you can download the CONNECT version of Configuration Explorer via the iWare pages.
https://store.bentley.com/en/products/iware/1000BCE--Bentley-Configuration-Explorer
Thank you for the answer it is very helpful.
Engineering Software Support Engineer
MS V8i SS2 v08.11.07.492
MS ORD-CE v10.09.00.91
I have downloaded it. thank you.
Good Morning David,
Thank you so much for the link! I was able to download the V8i Configuration Explorer and with a cursory look it seems to work. Thank you so much!
God bless,
David
