Good Morning Folks,
With regards to making CONNECT look like v8i by reverting the Ribbon interface to the former Task tools bar.
1. Does anyone have a real good reason for doing this? I think the Ribbon is a great idea but is there a situation where Task tool bar would have an advantage?
2. Has anyone run into an issue of changing the Ribbon in CONNECT to the Task tool bar?
Just curious, my place of work is planning on going to CONNECT at some point and one of the ideas to help with transition is to make CONNECT look more like v8i, but I question if this is a benefit?
Thank all of you for your time and your thoughts,
Should not be any issues, I'm sure many are want to do this. But I recommend adjusting to the ribbon, just because. I use the Task Navigation interface with a bit of custom ribbon.
