When opening TitleBlock.dgn with v8i - I can see and print Raster Reference attached to dgn file.
When opening same TitleBlock.dgn with Connect Edition Update 7 V 10.07.00.39 I can no longer see or print Raster Reference.
Open with V8i element properties:
Same file element properties opened with Connect:
I looked at configuration setting for:
MS_REF_DEFAULTATTACHDIRECTORY - it shows the correct default reference path
MS_RFDIR - it shows correct default reference path
Checked UPF and made sure Auto-update MS_RFDIR is checked in Raster Manager Category.
Not sure why Connect does not resolve and find raster image and V8i does find the raster image.
Connect View below:
Any ideas? Out of options.
TIA,
Roland Cyr
Found issue with MS_RFDIR configuration variable improperly set.
Thanks for looking, Roland Cyr
Thank you,
CE Update 7 - Version 10.07.00.39
Answer Verified By: Roland Cyr
