How do I stop files being linked to a workspace/workset?
CONNECT Edition is designed around WorkSets. If you followed suggestions made in other posts and created a single Workset for your team you would have less work to do fighting against the designed operation of the application.
You can use the MS_CONFIGURATIONOPTS variable to disable the WorkSpace and WorkSet creation options.
Marc
I have created a single workspace/workset as suggested but if I use it CE wants to link file to it, which I don;'t want, so back to using No Workspace/workset!! I would note that having created this workspace/workset it has made absolutely no difference to the speed of opening files. Still takes 2 - 3 mins to open an empty file, which makes CE very non-productive.
You will only see the link request for existing files, new files will automatically be part of the WorkSet.
For existing files:
"you can assign a WorkSet to multiple files using batch process:
This is from help topic Home > Getting Started > Fundamentals > Working with DGN Files > Including Files in the Active WorkSet
