Good Afternoon,I am trying to configure CONNECT so that I can keep the Workspaces on the local drive but to direct the child Worksets to a network drive. That way the standards (and any resource files) are local but the drawings can be accessed by all on the network.
The custom location of the WorkSpaces are here: C:\!msCONNECTconf\WorkSpaces (See Custom Folder in screenshot Workspaces.png)
I can create the WorkSpace for the Local Drive (See screenshot CONNECT_Open 2.png)
Afterwards I can create the WorkSpace for the Y:Drive / network drive and create a WorkSet and even a dgn within it, and everything appears normal in the current session of CONNECT, but once I Close CONNECT and try starting CONNECT, it will crash.This what I have for the "Local C.cfg" file:
_USTN_WORKSPACEROOT = $(_USTN_WORKSPACESROOT)$(_USTN_WORKSPACENAME)/_USTN_WORKSPACESTANDARDS = $(_USTN_WORKSPACEROOT)Standards/_USTN_WORKSETSROOT = C:/PIN/_USTN_WORKSETSDGNWSROOT = $(_USTN_WORKSETSROOT)/
MS_MACRO > $(_USTN_WORKSPACESTANDARDS)Macros/MS_VBASEARCHDIRECTORIES > $(_USTN_WORKSPACESTANDARDS)Macros/_USTN_WORKSPACEDESCR = Workspace used to direct to proper drive
And this is what I have for the "Network Y.cfg" file:
_USTN_WORKSPACEROOT = $(_USTN_WORKSPACESROOT)$(_USTN_WORKSPACENAME)/_USTN_WORKSPACESTANDARDS = $(_USTN_WORKSPACEROOT)Standards/_USTN_WORKSETSROOT = Y:/pin/_USTN_WORKSETSDGNWSROOT = $(_USTN_WORKSETSROOT)/
MS_MACRO > $(_USTN_WORKSPACESTANDARDS)Macros/MS_VBASEARCHDIRECTORIES > $(_USTN_WORKSPACESTANDARDS)Macros/_USTN_WORKSPACEDESCR = Workspace directs to Y drive
Is there some trick I am not aware of when creating a configuration in this way?Thanks for your Help and your time,
you also have a forward slash at the end of the _USTN_WORKSETSDGNWSROOT = $(_USTN_WORKSETSROOT)/ line. In the previous variable definition, it is already pointed to a folder, so the forward slash on the DGNWSROOT should not be needed.
Timothy Hickman
Main: 877 627 3772|
Good Afternoon Tim,
The company's Standards are kept at the Organizational level which would be everyone's PC. So the two Workspace configurations have very little in them except direction on where their child Worksets are located. Workspace "Local C" has its Workset location under the "Pin" folder on the "Local Drive / C". Workspace "Network Y" has its Workset location under the "Pin" folder on the "Network Drive / Y".
Thank you for your time,
could you get me a screenshot or a list of the files in the "pin" folder - looks like you just missed it in the last screen shot.
When the workspace is selected , does the proper list of worksets show for the user to select ? at what point does it crash ? (ie;do you get back to the start page, etc...)
Once you choose to create a Workspace and are in the dialog box to direct where the Worksets live and make these edits:
Once I hit Ok it crashs
