Good Afternoon,I am trying to configure CONNECT so that I can keep the Workspaces on the local drive but to direct the child Worksets to a network drive. That way the standards (and any resource files) are local but the drawings can be accessed by all on the network.
The custom location of the WorkSpaces are here: C:\!msCONNECTconf\WorkSpaces (See Custom Folder in screenshot Workspaces.png)
I can create the WorkSpace for the Local Drive (See screenshot CONNECT_Open 2.png)
Afterwards I can create the WorkSpace for the Y:Drive / network drive and create a WorkSet and even a dgn within it, and everything appears normal in the current session of CONNECT, but once I Close CONNECT and try starting CONNECT, it will crash.This what I have for the "Local C.cfg" file:
_USTN_WORKSPACEROOT = $(_USTN_WORKSPACESROOT)$(_USTN_WORKSPACENAME)/_USTN_WORKSPACESTANDARDS = $(_USTN_WORKSPACEROOT)Standards/_USTN_WORKSETSROOT = C:/PIN/_USTN_WORKSETSDGNWSROOT = $(_USTN_WORKSETSROOT)/
MS_MACRO > $(_USTN_WORKSPACESTANDARDS)Macros/MS_VBASEARCHDIRECTORIES > $(_USTN_WORKSPACESTANDARDS)Macros/_USTN_WORKSPACEDESCR = Workspace used to direct to proper drive
And this is what I have for the "Network Y.cfg" file:
_USTN_WORKSPACEROOT = $(_USTN_WORKSPACESROOT)$(_USTN_WORKSPACENAME)/_USTN_WORKSPACESTANDARDS = $(_USTN_WORKSPACEROOT)Standards/_USTN_WORKSETSROOT = Y:/pin/_USTN_WORKSETSDGNWSROOT = $(_USTN_WORKSETSROOT)/
MS_MACRO > $(_USTN_WORKSPACESTANDARDS)Macros/MS_VBASEARCHDIRECTORIES > $(_USTN_WORKSPACESTANDARDS)Macros/_USTN_WORKSPACEDESCR = Workspace directs to Y drive
Is there some trick I am not aware of when creating a configuration in this way?Thanks for your Help and your time,
if that pin folder is where your worksets exist (9204,18883, etc...) then there should be a *.cfg and *.dgnws file of the same name listed here. I do not see these in the screenshot. This is where you are telling MicroStation to look.
Timothy Hickman
Main: 877 627 3772|
Afternoon Tim,
The screenshot is of where Workspace "Local C" is directing it's Workset folder location. The Workspace "Network Y" is directing to another Drive altogether. Once I fill out the dialog box to create the "Network Y" Workspace and Click on "Ok" is locks-up and Crashes.
Peace,
where are the CFG and DGNWS files for the worksets ?
Workspace CGF is here: C:\!msCONNECTconf\WorkSpaces
Workset DGNWS and CGF is here: C:\PIN
the CFG and DGNWS files for the Y drive worksets, need to be in the Y:\PIN folder along with the rest of the data. I would suggest putting/moving them there.
