During my testing of setting up my configuration for Connect, I am running into a problem of a rouge folder being created (see image below). Can anyone tell me why the folder "Default" is being created automatically?
Gerard
I believe the Default is the Workspace that the workset is linked too.
HTH
Ian
I think Ian is correct. In the variable explorer dialog you attached it appears that you are using a WorkSpace named Project2. You can see this in the variable _USTN_WORKSETSROOT which is defined as "$(_USTN_WORKSPACEROOT)WorkSets\". (by default) and $(_USTN_WORKSPACEROOT) is set as "$(_USTN_WORKSPACESROOT)$(_USTN_WORKSPACENAME)\"
If that's not the case then you have other anomalies going on. Attaching a debug will help figure them out.
~HTH
John.
yep
Hi Gerald,
If you type 'default' into Variable Explorer's 'Expansion Filter' box do you get any results? That my point to the source of 'Default'.
Marc
