Customize Ribbon in Connect acts "glitchy"
After I had imported my custom dropdowns in v8i into connect, it has been found that moving menus around into different locations will not save out (they keep reverting back to their former locations when the "Apply" function is executed in the "Customize Ribbon" dialog. My feeling is that the OS we are using (Windows 7) may be the culprit and that operating Connect within Windows 10 "might" solve the issue. I will be getting a new laptop next week with Windows 10 preloaded, so such will be the time- I suppose- to test my hypothesis. Is this issue "alive" within the Windows 10 OS as well? As a side note- and as we are utilizing a network environment- I also tested this finding on a bare local install with the same results.
