I have made a custom dgnlib with a workflow that has tabs. I want to delete some of those tabs. I select the tab, select the Remove button, select Apply but the tab is not removed. Anyone else experience this same issue or know what is causing this?
Unfortunately, my local is clean of dgnlibs as I am managing a custom workspace where the dgnlib's are being called from. I filed a ticket and it was filed as a defect. They provided instructions on removing the tabs the manual way through an export of the ribbon to xml and then pulling it back in.
