Hi
I want to be able to have the links-tab in the explorer opened to a sertian level at all times. I've got the following setup and would like easy access to all the DGN-files, and therefore expand 3 levels automaticlly. Is that possible?
Robert
Having it open to a certain Level is not possible but if you are experiencing issues with the information loading taking a long time you may want to implement the use of the DGN Index Service.
https://communities.bentley.com/products/microstation/w/microstation__wiki/10630/dgn-index-service-how-to-set-up
Ok. I would be great if that would be possible. Or at least keep it opened to the same level when I swich between files, especially if I use the explorer. Becasue now it's almost as easy to press crtl+O and borwse there, instead of open all the tabs.
