While we are still working in V8i, we are also watching Connect Edition developments as we know we will eventually wind up there.
What I am looking for a some type of explanations and guidance on Connect Edition Workspaces and what is new, what has been migrated. I'm pretty comfortable in my V8i Workspace and modifying them. But Connect seems to be a new beast, with new terminology and I was hoping that there is some guidance available, rather than having to brute force my way into Connect Workspaces.
Shaylesh has included a table of contents for configuration blogs which helps with navigation.
Some fundamental points are:
Standards can be defined and stored at any of these three levels depending on the granularity/control/variation required. These choices may also be guided by archiving requirements as John has indicated.
The start from scratch approach has a lot to commend it, build the structure then pull resources from V8i into the appropriate places. Obviously that is a simplification, but it should filter out configuration "tricks" that were needed to work around V8i that are hopefully not relevant to CE?
Marc
Answer Verified By: caddcop
IMHO, this has turned into an Excellent thread. I hope others find it a useful topic.
