Hello, I need change Touch Mode on default. How to do that?
I need buttons with text about.
Hi Iren,
I am not sure whether I understand what your question is. Or are there two questions in fact?
Please follow communities best practices:
With regards,
Jan
Hi,Jan
It is microstation v8i
Can you see diferences between pictures? I need view of ribbon as on pictures 2.
Iren Timoty said:It is microstation v8i
Evidently it's not, because ribbon GUI is available in CONNECT Edition only. But what CE version?
Iren Timoty said:Can you see diferences between pictures?
The pictures display two completely different GUIs, I am not sure about the first one (is it part of ribbon?), the second one is MicroStation ribbon as defined for Drawing workflow.
It's not clear what difference do you mean.
Iren Timoty said:I need view of ribbon as on pictures 2.
I do not understand what does it mean "I need view" :-(
Do you have own ribbon customization definition in dgnlib? What workflow the first picture displays?
I made ribbon customization definition. This is command from microstation`s utilites is named as "Touch Mode". I click on it, and from pictures 2 I got the situation as on pictures 1. I don`t know how turn back ribbon 2. When I click again on "Touch Mode" nothing happen.
Ok, now it makes sense ;-)
File (backstage) > Settings > User > Preferences, category Ribbon, Ribbon Size = Small
Answer Verified By: Marc Thomas
