Detailing symbols are working fine in V8i . Trying to get them to work in Connect. When I go to create them I keep getting and error message
The pull down to attach the cell under the Tail wing populates with nothing from my cell library.I have these set in my standards.cfg fileMS_DETAILINGSYMBOLS_CELLLIST = $(_USTN_ORGANIZATION)dgnlib/DrawComp/*.celMS_DGNLIBLIST_DETAILINGSYMBOLSTYLES = $(_USTN_ORGANIZATION)dgnlib/DrawComp/WWE_DETAILING_SYMBOLS.dgnlib
In CONNECT Edition MS_DETAILINGSYMBOLS_CELLLIST is no longer available, See the following threads:
https://communities.bentley.com/products/microstation/f/microstation-forum/112088/ms_detailingsymbols_celllist-removed-in-ms-connect
https://communities.bentley.com/products/building/building_analysis___design/w/building_analysis_and_design__wiki/35489/connect-edition-deprecated-configuration-variables-for-the-connect-edition-platformmicrostation
Carl Myhill
Technical Support Engineer
Bentley Systems
