I seem to remember I was able to change the tool that was displayed when Microstation started.
I would like to change the tool Drop Element to Create Region, is this possible?
Thank you in advance
activate the tool you want ie drop element and save settings then exit?
Lorys
Thanks Lorys,
But it didn't work. I tried other tools and the tool that appears on startup always appears the same.
at first, I recommend to read and follow Administration Forum best practices.
Can you specify what product and version do you use? From the screen capture we can assume it's MicroStation, but it seems it's some quite old version, because Main pallete has not been used for years.
Jan
The only options on start up are for the active tool to be 'selection' or 'none' in V8i and CONNECT Edition.
If you want a particular tool to always be displayed in the pre-V8i Main Tool Frame I think you will need to look into the customization features.
Marc
Thanks Marc Thomas, I guess my screen shot has everybody thinking I am using an old version. The version I am using v8i SS4 ver 08.11.09.832
I really don't like the new look and haven't since it cam out. Since it all works the same I have kept microstation looking like something I am comfortable with one big reason I am waiting to move to connect (I have read too many complaints just out of the box) So I'll just wait until I can read more (or less) complaints.
Thanks again for the information
