I have been trying to make some sense of workspaces and worksets and if they will work with our internal systems. See my earlier thread about this.
To check on this I did the following:
Basically, if this is to work for us, we just need the workset to point to the server for the standards information and the job folder for everything else. If it can’t do this then it’s back to No Workspace>No Workset.
Any help would be appreciated.
Stuartw,
I'm right in the middle of setting up CONNECT and OpenRoads designer. I'm still figuring out how all the config files relate.CONNECT is looking for a certain folder\config file relationship that didn't work for me - I put the standards and config files (read only) on a server and have separate project folders for all my design files. Here's what I ended up with: CONFIGURATIONSETUP.cfg points to WORKSPACESETUP.cfg in my"organization" folder (I don't have much at this level) which then points to the client config files in a "workspaces" folder. Each of the client config files point to a client standards folder which has a worksets subfolder (for me these are different projects). The workset is where I specify the location of the dgnws file (per project).
A few things I've learned:To set up a new project I have to go to my worksets folder, copy and edit the cfg file, I can't use the automatic setup in the "Create Worksets" on the backstage and don't let CONNECT automatically create folders.You can control what loads at what level using "=" ">" "<" same as it's always been with config files.The dgnws needs to be in a read\write location.
Hopefully you find the above more helpful than confusing. : )
Tom F.
