Is there a way to prevent line style to populate from only "choosen" library? like a certain variable maybe?
Let me explain: Sometime I need to create dgnlib that contain title block or other stuff, but the line style that are present in those library get duplicate. So when I create a new file I get 2 times some line style.
Thanks everyone for your help.
after creating the file the best option is to compress the files with the option to delete unused linestyes. see help
Process the DGNLIB's pointed by MS_DGNLIBLIST_LINESTYLES for available library LineStyles
Try that variable. Of course this doesn't stop any linestyle from being in a file if the linestyle is in the seed file.
~HTH
John.
yep
