Keyboard shortcuts
Hi
I'm running Aecosim connect and have two sets of keyboard shortcuts. One for 3D-modeling and one for annotation and sheet-management.
Not sure how other program works, but Aecosim has two different startup-modes with different icons. One microstation mode, and one for building designing. Right now I use these different modes to deside which set of keyboard shortcuts I run. But it would be nice to be able to switch between them while the program i running. Is that possible? Or do microstation need to be shut down in order to change keyboard shortcuts?
Robert
  • You could try something with changing the configuration variable that points to the keyboard shortcuts file.
    expand set MS_KEYBOARDSHORTCUTS = $(_USTN_HOMEPREFS)fileA.xml
    expand set MS_KEYBOARDSHORTCUTS = $(_USTN_HOMEPREFS)fileB.xml
    I was able to get it to change the file to write to but I wasn't successful it getting it to load the data from the file.
    ~HTH
    John.
    Don't be afraid to question the status quo
