Is there a way to create sub-categories from the Work Page Workspace pull-down selection?
Currently I see the "Example Configuration" and the "Custom Configuration" sections. I would like to create my own section for "OpenRoads Design configuration" so that it is separate from the typical
workspace clients. I would include FDOT and ILTOLLWAY from my pic into a OpenRoads Design section.
Using MicroStation CONNECT Edition 10.11.00.36 Update 11.
There is a _USTN_USER_CONFIGURATION variable that works similarly to the _USTN_CUSTOM_CONFIGURATION variable.
You can set up your configuration to have all three (Example, Custom, and User) defined.
Rod WingSenior Systems Analyst
I set the variable _USTN_USER_CONFIGURATION and it replaced the Custom section heading with the word User. I was hoping to be able to utilize a different label such as OpenRoads. I couldn't get the Workspace pulldown to show all three sections (Example, Custom, and User). I need to play with it some more.
Any suggestions to show all 3 sections as you mentioned above?
Here is an example I put into a system configuration file that gets loaded prior to the C:\ProgramData\Bentley\MicroStation CONNECT Edition\Configuration\ConfigurationSetup.cfg file being read in.
_USTN_CUSTOM_CONFIGURATION=Q:/Configurations/Configuration_Power Company/ _USTN_USER_CONFIGURATION=Q:/Configurations/Configuration_DOT/ %lock _USTN_CUSTOM_CONFIGURATION %lock _USTN_USER_CONFIGURATION
