How can I elongate the address toolbar? It seems like it should be a simple fix, but I can't find the answer for the life of me. Any help is appreciated!
If you customize the Quick Access Toolbar by adding icons it will increase in length.
I don't think I was clear in my original post... I need the search field to elongate in the address toolbar...
Click and hold on the 4 vertical dots to the left of the search bar. Drag down. This will detach it the bar from the toolbar. Lengthen the bar once it is detached by dragging the right side of the search bar. Then redock it by dragging back. It will retain the new length.
I knew it had to be something super simple, haha.
Got it fixed - thank you!
