There are a lot of MicroStation VBA examples with (auto-)scanning dgn files etc. But I would need the commands/syntax for capturing the text element contents (text string) by a manual click (datapoint) from the user on the text element. And then use that saved string to attach a ref file of the same name (eventually same name with prefix or suffic e.g. + "_2016.dgn").
Thank you very veru much in advance for any help,
Best regards,
Nicolas Tobbackx - Brussels
