In V8i, I had a heavily customised tasks panel which I have managed to load into CE without any problems. What I am investigating is to see if I can arrange the tools I use in an acceptable manner using the Ribbon.
Starting at my main task, I had 2 rows of tools so I have added 2No. panels nested in a group (set to horizontal) but I don't appear to have any control over the wrapping or width of group.
This is what I am trying to replicate:
Is this achievable?
Hi Barry,
did you review the following Blog? https://communities.bentley.com/products/microstation/b/microstation_blog/posts/customization-blog-series-designing-a-ribbon-group-pop-up---blog-2-of-2
Maria Garcia
It turns out I had the lower tools not placed within the lower panel so its fixed now though it looks pretty awful. Is there any way to control the height of the ribbon as its a bit on the large side?
Also (not sure if its been reported already), I noticed when tidying up my task tools (removing tools which no longer work etc...) that the tool DIMENSION ELEMENT tool is bugged when used in a task as it displays the wrong icon (yet hovering over the tool does say Dimension Element) however upon pressing it loads a tool called Dimension Element Constraint.
