I'm not sure whats going on with this one. At home when I configured my CONNECT installation to use my V8i tasks everything showed up however I am in the office today and have done the same yet my Main Task is showing the default Main Task and not my own. I've gone into my dgnlib where the task is configured but there is no option in the Customize dialog Properties section to allow me to assign the Main Task.
Any ideas?
Hi Barry,
Is the dgnlib placed in a folder as specified in the configuration variable MS_GUIDGNLIBLIST
Where did you place the dgnlib?
After doing all the changes did you close MicroStation and reopen it again so all the changes are taken into account
Review https://communities.bentley.com/products/microstation/w/microstation__wiki/25797/how-to-migrate-old-customizations-to-the-ribbon
https://communities.bentley.com/products/microstation/w/microstation__wiki/24469/how-to-customize-v8i-menus-in-connect-edition
Maria
Maria Garcia
Hi Maria,
Yes the file is within a folder that MS_GUIDGNLIBLIST points to. The below image shows that it is NOT possible in CONNECT to assign a main task nor any other property with the exception of 'Show in Toolbox List'.
Any update on this Bentley?
