Task Replacement Options
In XM, Tasks were introduced as a way to tie together things that used to be found in Settings Manager. You would have Element Templates for the graphic standards and tools to combine a tool with an ET and finally place that in a Task pane.
With Connect, tasks are deprecated. According to the newsgroups it is possible to resurrect Tasks using some CFG variables. However, In practice, this failed for our needs as we will be using Open Roads Designer, and when the method is attempted, part of the ORD interface gets hidden. We have determined that disabling tasks will restore the missing tools.
So, with tasks not an option, what does Bentley recommend for users who had a large array of Task panels?
In all honesty, we currently use Bill Steinbocks Barmenu MDL in V8i to combine ET's with specific tools. but since menus are not part of the interface in Connect, a Barmenu seems anachronistic and would seem out of place - assuming we could get it to recompile for Connect.
  • Chuck,
    You can still create tools based on Templates and Tools as you describe above. These can be put on Ribbon Workflows/Tab/Groups.
    The same WorkFlows you had before can now be arranged on Ribbon WorkFlows.
    ~HTH
    John.
    yep
  • We use a VBA macro to evaluate a file name and load a barmenu based upon that value. However, we also allow a user to manually load a different menu.
    To implement this workflow in the Ribbon, we would need to have a show/hide test that works in a similar manner. Upon file open, it shows the Ribbon Tab appropriate to the current file. But then allow the user to select some tool that allows them to change something that would hide the current file  Ribbon Tab and Show the Ribbon Tab for the item the user selected.
    I've seen show/hide tests that parse filenames to locate the characters that identify the file type, but can a show/hide test read a configuration variable, that we allow to be revised in mid session and once its revised, the Ribbon be forced to refresh and reevaluate its show/hide tests, effectively turning off one Ribbon Tab and turning on a different Ribbon Tab dynamically?
    Charles (Chuck) Rheault
    CADD Manager
    Maryland DOT - State Highway Administration User Communities Page
    • MicroStation user since IGDS, InRoads user since TDP.
    • AutoCAD, Land Desktop and Civil 3D, off and on since 1996
  • Chuck, I actually wrote about this back in the beta testing days. You could use your vb to set a config variable and use Named Expressions to turn on\off the ribbons you want to use. Users could also hit a button that simply sets a config variable and refreshes the interface. Again, the Named Expressions would turn on\off the ribbons.
    Have a look at:
    https://communities.bentley.com/other/old_site_member_blogs/peer_blogs/b/bear_blog/posts/microstation-connect-control-workflows-via-named-expressions
  • Hi Chuck,
    As explained in Bear's link, it's possible. In fact you can implement 2 different types of tests:
    • Whether the configuration variable is defined: In some scenarios it's enough to know the variable exists and you do not care about  its value.
    • What value is assigned to the variable: It's useful when different values represents e.g. different show/hide ribbon configuration. Because show/hide expression should returns bool (true / false), often it leads to separate test for every checked value.
    You have to force the ribbon rebuild yourself using "ribbon rebuild" key-in after the variable value is changed.
    A problem with ribbon rebuild is that it's awfully slow, which is not an issue sometimes, but sometimes it slow down using MicroStation. I assume your question belongs to the first case, because the variable will be probably not changed too often.
    Be aware that the ribbon customization through standard GUI is just a first step / basic level. The ribbon itself, as it is implemented in MicroStation, offers better and more flexbile customization, but not all these advanced features are available in GUI now.
    For example, when ribbon customization is defined using XML (syntax is described in MicroStation SDK documentation), it's possible to define show/hide test for a tab and to bind this test with some event (predefined group of events is available), e.g. element is selected or active model is changed. This solution does not require to rebuild the ribbon, because explicitely defined show/hide test is reevaluated when the event is fired, so it's also much faster (example is context tab displayed when table element is selected).
    With regards,
      Jan
