How to modify a deployment image
I want to modify a deployment image created using the /layout mode
I see no way to easily launch the install options, otherwise I will have to start again and with OpenBuildings that's a few gb download again
Cheers
Chris
Hi Chris,
If you are happy with editing XML you can make copies of the original deployment image then modify the layout file, please see [OBD U5] creating deployment image without redownload the whole thing for more details.
Marc
Answer Verified By: Chris Dixon
Thanks Marc,
I will give it a try
