[CE] is there a class, webinar or someone that could help me out. I'm new at being admin for our team (the last guy retired) I don't know a lot about being Admin. I'm trying to figure stuff out, but I think I'm confusing myself more.
Some things are: how to update Connect Edition from 9 to 11?, How to make it so the team can not update there connect edition? and any other admin stuff I don't even know about.
We can definitely help you out in that department, we see a lot of people thrown into the same situation.
I happen to be running a CONNECT CAD Manager class this week. You can find our course description here...
https://envisioncad.com/product/cad-manager-microstation-connect-edition/
You can contact me via email (rod@envisioncad.com) so that we can discuss what your needs are and how we can best address them.
Rod WingSenior Systems Analyst
You should be able to shut off the Updates that show up in the Connection client by:
This policy does not apply to the CONNECTION client itself, it will still prompt for updates of the client (I've found no way to turn this off), but it will turn off prompts for other software.
If you don't see the Software Administration tile you probably don't have a permission set in Bentley's portal, contact Bentley to get that fixed.
The following Wiki article brings together a lot of detail regarding the upgrade and administration of MicroStation CONNECTEdition, including various training sessions available from the Bentley Learn Server.
https://communities.bentley.com/products/microstation/w/microstation__wiki/39386/upgrading-to-microstation-connect-edition
