I have a customer Workspace that contains a list of Worksets. These worksets are for the customers differnt crafts. We are using mainly one particular craft.
When I am Picking this customers Workspace I Always get the first workset alphabetically. (I renamed the first one and now I am obviously get the next one) So I have to scroll down the list of worksets and select the Right one down the list.to make sure I am working with the correct crafts workset. I would like to get our "preferred" craft selected.
I tried "_ustn_worksetname = >CRAFT<" in the Customer_workspace.cfg, but this config var is not steering me there.
The last used combination of WorkSpace and WorkSet should be used when microstatin is opened if this is not happening you may want to check the rights on the prefs folder.
mlm said:_ustn_worksetname = >CRAFT<
This is read at startup from the personal.cfg to determine the initial workspace/workset combination.
mlm said:The bulk of files has not yet been branded. They are pre-Connect. We also will get a constant stream of thrird Party files that Need to be assinged to the right project.
You may want to try to bulk associate using the batch process these files similar to the following article:
https://communities.bentley.com/products/microstation/w/microstation__wiki/32023/how-to-break-the-association-between-certain-files-and-a-specific-workset
the keyin you would use file associateworkset
It would be nice to do this on the fly.
MaryB
I went back and reread this. Sorry I missed that you just want to set a default WorkSet for the WorkSpace. It really has nothing to do with the User as you want all users to start with the same default craft (WorkSet).
IMHO this is a bug, what you did should work. In V8i you could define a User to select a specific Project by setting _USTN_PROJECTNAME in the User CFG file. In CONNECT User is essentially WorkSpace and Project is WorkSet. So you should be able to set a WorkSpace to have a default WorkSet by defining _ustn_worksetname in the Workspace CFG file.
I would contact Support and ask them to file a defect on this issue. But again thats IMHOWDNM
~HTH
John.
yep
Gerd,
While we don't maintain a shared recently used list for each WorkSpace, each user should build up a list of recent WorkSets on the Backstage:
This cannot be pre-populated (as far as I know), but once a user has selected and used a WorkSet it should be listed here. Does that meet the need in part at least?
Marc
