Hello everybody,
in our organization we work in a workspace/workset configuration within our cad operators have to load/open different dgn files not assigned to any worksets.
Is there an environment variable/method/function im CONNECT to suppress the workset verification? Because the dgn files were manipulated from different worksets. An assignment to only one workset isn't practical.
I moved the dgn files to directories the variables MS_WORKSETMISMATCH_ALERT_EXCLUDE_* are pointing to but at all times the workset alert message appers.
best regards
Daniel
Hi Daniel,
The steps you have taken appear to be in line with our guidance, where in your structure are the folders containing the files that still flag the alert?
Marc
Hi, Mark. We aslo experience issues With Variables MS_WORKSETMISMATCH_ALERT_EXCLUDE_*. Tried to set them to $(_DGNDIR). Does not work. The WorkSet Alert Dialog pops up.....
Roald
Hi Marc,
the dgn files are within a folder reached by MS_SEEDFILES. My last attempt was open the files from _USTN_WORKSPACESTANDARDS)seed\.
This will need some more investigation.
I can reproduce the behaviour with a dgnlib from one of my workspaces that should be omitted from the mismatch check by both variables.
are there any news in this topic?
regards,Daniel
