We are going through a large PC refresh and a significant number of our new machines will be laptops. We are trying to work how to have the configuration (cfg) available to the laptop machines when offline. We have set up a sync from the network to the local machine for the cfg. and I have edited the ConfigurationSetup.cfg as follows;
[General] _PDT_nDrv = M:/ _PDT_lDrv = C:/ _PDT_locCFG = PennDOT_CE_Configuration/ %if exists ($(_PDT_nDrv)$(_PDT_locCFG)*.cfg) _PDT_Drv = $(_PDT_nDrv) %else %if exists ($(_PDT_lDrv)$(_PDT_locCFG)*.cfg) _PDT_Drv = $(_PDT_lDrv) %else error Exiting, No network or local Configuration found %endif %endif _USTN_CUSTOM_CONFIGURATION = $(_PDT_Drv)$(_PDT_locCFG) [SetConfiguration] %if !defined (_USTN_USER_CONFIGURATION) %if defined (_USTN_CUSTOM_CONFIGURATION) && ($(_USTN_CUSTOM_CONFIGURATION) != "") && exists ($(_USTN_CUSTOM_CONFIGURATION)) _USTN_CONFIGURATION = M:/PennDOT_CE_Configuration/ %endif %endif
Unfortunately line 21 doesn't seem to like being redefined to a new value.
Here is my debug for this section, note line 9 and 10;
Processing macro file [C:\ProgramData\Bentley\MicroStation CONNECT Edition\Configuration\ConfigurationSetup.cfg] (System): _PDT_nDrv=M:\ [M:\] (System): _PDT_lDrv=C:\ [C:\] (System): _PDT_locCFG=PennDOT_CE_Configuration\ [PennDOT_CE_Configuration\] Starting skip to endif, [C:\ProgramData\Bentley\MicroStation CONNECT Edition\Configuration\ConfigurationSetup.cfg], line 27, depth = 0. (System): _PDT_Drv=$(_PDT_lDrv) [C:\] Starting skip to endif, [C:\ProgramData\Bentley\MicroStation CONNECT Edition\Configuration\ConfigurationSetup.cfg], line 32, depth = 0. endif, [C:\ProgramData\Bentley\MicroStation CONNECT Edition\Configuration\ConfigurationSetup.cfg], line 34, depth = 0. (System): _USTN_CUSTOM_CONFIGURATION=$(_PDT_Drv)$(_PDT_locCFG) [C:\PennDOT_CE_Configuration\] (System): _USTN_CONFIGURATION=M:\PennDOT_CE_Configuration\ [M:\PennDOT_CE_Configuration\] End of macro file [C:\ProgramData\Bentley\MicroStation CONNECT Edition\Configuration\ConfigurationSetup.cfg]
I have also tried to defining line 21 to use a variable and not be hard coded but that doesn't seem to work.
_USTN_CONFIGURATION = $(_USTN_CUSTOM_CONFIGURATION)
Any help on how others would be handling configurations for laptops would be helpful. I would prefer to not use different icons for Network and Local configurations.
Marc has stated most of the issue. It looks like you are modifying the "set configuration" area - this is intended for the last configuration loaded and is stamped there by MicroStation.
The other part of your question about the whole file being overwritten is correct. When an upgrade happens, this file gets overwritten. The only thing that would get saved from the original file is the _USTN_CUSTOM_CONFIGURATION line - everything else you added would get wiped.
Timothy Hickman
Main: 877 627 3772|
Hi John,
We have Enhancement 854340: "updates overwrite the ConfigurationSetup.cfg" suggesting that we do not overwrite ConfigurationSetup.cfg during upgrades, but append any changes that we need to existing instances of the file.
Please file an SR referencing this enhancement if you would like to support this suggestion.
Marc
Thanks.
If they were to fix the first part and make it so it uses a variable and them the upgrade process only overwrite the information under[SetConfiguration] that would be a great help.
~HTH
John.
yep
Mark or Tim or anyone,
Is there a way to include this more complex ConfigurationSetup.cfg in our layout for installation?
this whole area is being debated in house currently.
