Does customize dgnlib support bilingual?
Hello All,
I created some tools and customized task/menu accordingly. I'd like to know does dgnlib support bilingual? I created two menus right now, chinese and english version. Both menu will show. If MS can hide one menu according to the windows/MS version, it would be prefect. I don't want to create two dgnlib. Thanks a lot.
  • Hello Kim,
    I have already did so. it works in V8i, but failed in CE.
    Does it work on your CE? According to my setting, if there is no variable PINEAPP_LAN defined or its value is EN, only the english ribbon show; if PINEAPP_LAN is CH, only the chinese ribbon show. But none of them show in my CE regardless the variable PINEAPP_LAN.
    BTW, did you notice that there is a "custom" suffixed on my chinese ribbon but not on the english ribbon. Shouldn't them be same?
    Thanks a lot!
  • Hello Mr. Ling,
    CE is very different with V8i in localized language. In CE, you can change your MS language by selecting File > Settings > User > Preferences > Language with only one MSCE installation. So I don't think it is a good idea to define a variable to determine what language you use.
  • Hello master Fu,
    In fact I didn't access MS language, I defined a variable and named expressions to control which ribbon/menu/task to show.
    I think it is better to use a variable to control the ribbon/menu/task, since all the MS/windows are probably english version, but I'd like to show chinese menu for chinese users who is using MS/windows english version.
    The menu/task works fine in V8i, but ribbon doesn't work in CE, even I have checked the named expressions in CE, they are OK.
    Would you please try the dgnlib in your CE? None of them show here. Thanks a lot.
  • The way that we handle language support has changed in CE, which I did not take into account in my initial reply. Each of your users can now select their preferred language in User Preferences, which should be remembered between sessions:
    That may be the appropriate solution here. If you change this preference from the default of en to zh are your custom menus translated correctly?
    Marc
  • Hello Marc,
    There is only one language En in my CE, So I cannot test.
    My assumption: there is no MS language in V8i, the menu is fully controlled by named expression. But for CE, even the named expression is True, but if the language of the ribbon does not match the language of CE, it won't show neither.
    For CE, the best way might be set display "always" on the different ribbons, let the MS language determine which one to show.
    If so, there is another problem, for example my case here, I cannot show chinese ribbon on english MS?
    Thanks a lot.
