Hello
I have an issue with none microstation user colleagues moving photos & pdfs i have attached to a microstaiton drawings or moving the project file completely, which then drops the links to the raster files attached. Is there a way i can make Microstation automatically save relative path to raster files?.
The photos i attach are from different folders each time so setting it to one folder is not what im looking for. I just want it to auto save relative path.
I looked through loads of existing questions on this but i could not seem to find a relative answer. Im using Descartes stand alone V8I Series 5
i know where the files are kept its just different for every project but i was trying to set it to a higher folder so once the project is complete and the file is moved from "current projects" to "complete projects" it retains the paths.
For example. The file path would be as follows
Projects/current_projects/Private/Draw_photo/photos/2019
I was trying to set the expansion to "Projects" so it covers anything moved around under that.
There is no chance the company will let me redesign the digital filing system to account for CAD issues. I cant even reset expansion even if they would lol
If you do not use customized configuration files for each project you may have a hard time accomplishing the task at hand. The power of configuration files is invaluable. You do not need to worry about saving relative paths with config variables defined properly. Using MS_DEF & MS_RFDIR will handle finding the files as long as you have the folders defined to be searched for references. If the folder structure is standardized and the only thing that changes when moving files to a new drive or server all you need to do is change the definition of MS_DEF. You don't need to redefine your digital filing system. You will need to research configuration variables. At minimum you should have project specific configuration files to alleviate your problem.
ORD - 2021 R1 10.10.1.3
ORD 2022 R1.1 - 10.11.3.2
ORD 2022 R3 - 10.12.2.4
ProjectWise - 10.0.3.453
Thanks for your reply.
I see a few of you using MS_??? descriptions. can you explain what you mean by this?
mwlong said:change the definition of MS_DEF
How?
Search for Working with Configuration Variables in your Help file. This is a very broad subject and would take a long time to explain everything. It will take time for you to set some stuff up. Their is also an Administration forum to post specific questions once you get into it if you choose to do so.
