I am struggling with worksets, and in particular with the Browse button. I get this:
Same thing with a brand new workset by clicking Create Workset.
I would very much know which path it is, which does not exist.
Seems line first line of the alert box is empty, but that does not help a lot.
regards, Lars M-P
It's looking for the path of MS_DEF. There is something weird that is going on with MS_DEF being set to _USTN_WORKSETDGNS by default. I just set it to what I need in the actual workset.cfg. If you attach a debug and maybe we can help a little more.
~HTH
John.
yep
Thank you, John. MS_DEF did the trick
