HAS ANYBODY HAD PROBLEMS WITH THIER CURSOR TURNING BLACK, TO WHERE YOU CAN'T SEE IT?
This happens a lot. Can't recall the solution, search em up.
There is this- (Connect r12)
Thank you Bob but I have checked that. I really believe it is a graphic's card problem. Can someone give me the requirements on requirements on Graphic cards. This has happened a lot with different machines.
There have been a number of instances where the cursor is turning black where it is in relation to high definition monitors. The following Wiki has previously been of assistance in these circumstances.
https://communities.bentley.com/products/microstation/w/microstation__wiki/31077/user-interface-tips-for-high-resolution-monitors
If this does not help then you might like to quote Defect # 711886 within a new Service Request
Answer Verified By: Marc Thomas
Thank you Andrew, that worked!
