I have been customizing CE for years to make it look and feel as close to V8i as possible. With this I created new DGNLIBS to host the customization ie tasks.
This process works fine for CE12 and earlier versions. However, in CE13, it caused me an issue, where the 2d 3d workflows stopped working. Thus If I am in a 2d file I do not see the 3d tasks.
Within U13 they added a DGNLIB called V8iTasks.dgnlib (I dont think it was there before), which is located n C:\Program Files\Bentley\MicroStation CONNECT Edition\MicroStation\Default\GUI\Archive\en\
You need to copy this to your Organisation > DGNLIB > GUI folder for the full Tasks to be exposed.
Now I see a true V8i Task dialog
HTH
Ian
Hi Ian,
I tried that but it doesn't function with hotkeys. They work under the 'Task Navigation' selection but not in any of the others
