[UPDATE]
I'm using MicroStation V8i (SELECT series 3) and I want to make some changes to a "User-defined" toolbox created many years ago with another version.
This toolbox sets active a pre-established layer, linking everything I draw to a specific layer with specific parameters. Let's say we have the layer "Corte" associated to the first tool of this toolbox. If I select this tool, it then starts to place a line on "Corte" layer, with same colour and width established to that layer. This Toolbox is called "linhas".
For that to happen, a DGN file (named "niveis") was created in order to have those layers information, although it's not possible to draw in this file. It seems like it's used as a seed file further on, as fas as I know. This file is located in Workspace > Standards > Seed
I now basically just want to update some of their colours, as well as adding a new tool for a new layer, and for that I need to edit the original Toolbox setup. I've created a layer called "TESTE", which I want to be yellow. I want to add a tool that automatically associates what I draw to that layer.
When I open the "Customize" window, this toolbox appears on the "Application Tools > MicroStation" rather than "User Tools". I've digged a lot in this and other forums, and they all suggest that new toolboxes should be created in User Tools with DGNLIB files.
The next image shows what it looks when I reach the toolbox "linhas". It looks nothing but editable.
I've searched in every MIcrostation's data folder, and none of them has any file with this toolbox's name. I need some help locating this file so I can edit it.
My conclusion is that it was made right down the code. I need to reach the right file so I can edit it. I'm possibly looking for a .RSC or .MA file, so I can edit using MDL tools.
Another possible scenario is that, since it was created many years ago in an older version of Microstation, it may have been created in "User Tools" as a DGNLIB, and when it migrated to newer versions, it then went to Application Tools.
Any suggestions?
Thanks in advance
This looks sort of like Element Templates to me. With an Element Template you can define the parameters like your current tools seem to do. Look up Working with Element Templates in the help file. You can create a .dgnlib to make them available across all files.
Microstation CONNECT 10.17.00.209
ORD CONNECT 2021 R1 10.10.1.3
Microstation v8i SS 10 08.11.09.919
Power InRoads v8i 08.11.09.615
ProjectWise 10.0.3.453
no, the tools evoke key-ins as we can see now. the key ins set color etc... just like templates WOULD do (and easieer). But she is right that it looks like the key in is not editable. Jan is possibly right and they don't come from a dgnlib... If they would the dgnlib should be listed in the customize/file dialog, as I mentioned before...
Also the location where to find the files should be obvious -> MS_DGNLIBLIST or MS_GUI_DGNLIBLIST
Sorry, I wasn't trying to suggest they were element templates. I was merely trying to suggest using element templates rather than creating new tools. Why go through all the trouble of creating a new tool when element templates can handle this task? It seems that the tools may have been made prior to element templates (don't know what version they were introduced) and that custom tool was just brought forward rather than recreating in a new tool.
