v8i SS10 08.11.09.908
Win 10
Network workspace shared
I put together a task list with our standard set of tools (symbols) used in the schematic design process. How can the "default" tasks be disabled or removed from the list??
There is a file GUI.dgnlib that contains these task. I would not recommend just removing this file as this file contains other GUI element not just the delivered tasks. You can open the file and delete the tasks from the file so they no longer show up.
You may also find the following article helpful:
https://communities.bentley.com/products/microstation/w/microstation__wiki/10364/customizing-tools-and-tool-boxes-in-microstation-v8i
Hi Stephen,
The V8i Task navigation tasks included in MicroStation CE Update 13 are contained in C:\Program Files\Bentley\MicroStation CONNECT Edition\MicroStation\Default\GUI\Archive\V8iTasks.dgnlib included in the list of DGNLIBs defined by the MS_GUIDGNLIBLIST variable.
Ad the DGNLIB containing your tools to this variable (most easily by putting it in one of the locations already included) then it will be available for selection in the task tree menu (3 on the illustration).
Marc
