Hi
I think I've seen this question somewhere before, but I can't find it now (looked everywhere):
In my configuration, I want to separate our workset folder from our .dgnws and .cfg. The reason is on our server P:/ we store all our projects and we want them to be stored right in that folder, not under a workspace folder, nor do we want those configuration-files to clutter that folder. I've manage to set that up, so on R:/ we have workspaces (both it's folders, and it's cfg-files) and the worksets cfg and dgnws-files. And on P:/ we have the workset's folder with both models and workset-standards-folder.
Now to the problem. With this set up the files and folders don't get copied from the template workset, to my P:/ location (or to the R: either for that matter). We've got to manually copy a folder, which not all users have accepted.
Last time I saw this problem somewhere, I think one Bentley-employee answered this was a known problem, but this would get fixed. What's the status of this?
Robert.
Hi Robert, I think it was me. We have made some fixes in this area but I'm not confident that we have resolved this yet. I was testing this exact function a few days ago and encountered the same behaviour. I'll let you know what develops over the next coupe of weeks.
For the moment when the (entirely logical!) split you describe is implemented manual creation of the missing WorkSet folders is the best solution.
I was testing this a few days ago (I've been away) so will report back on anything new that I find or we progress with.
Marc
The templating of WorkSets just doesn't work right. It may have gotten better with u13 but I haven't had time to test it.
I wrote a VBS file to do what you want. Give it a try if you like.
YOu will need to define 2 thing (where it puts the CFG for Bentley's application to read, and where it finds the seed worksets);
Option Explicit DIM fso Dim sh DIM wsSeedDir Dim wsSeedRoot Dim wsSeedFile Dim wsSeedDGNws DIM prjNum Dim prjCfgFile Dim newText Dim objFile Dim strText Dim compText Dim prjPath Dim prjRootPath Dim existsCopyFile Dim msg Dim title Dim strPrompt Dim intOptions Dim wsSeedRoots Dim rv Dim prjDestFolder Dim worksetCfgDir Dim rem1 Dim rem2 Dim rem3 Dim iNumberOfLinesToDelete Dim arrLines Dim i Const ForReading = 1 Const ForWriting = 2 Const ForAppending = 8 Const WINDOW_HANDLE = 0 Const BIF_EDITBOX = &H10 Const BIF_NONEWFOLDER = &H0200 Const BIF_RETURNONLYFSDIRS = &H1 Set fso = CreateObject("Scripting.FileSystemObject") Set sh = CreateObject("Shell.Application") strPrompt = "Where is your project stored?" intOptions = BIF_RETURNONLYFSDIRS + BIF_EDITBOX + BIF_NONEWFOLDER rem1 = "#======================================================================" rem3 = "# Set the WorkSet root folder" iNumberOfLinesToDelete = 4 'This is the location it puts the cfg's for the application to find, 'the application must be configured to read them at this location worksetCfgDir = "M:\PennDOT_CE_Configuration\WorkSets" 'This is the location it will find the seed WorkSets located, 'both a CFG and parent folder need to be located here. wsSeedRoots = "M:\PennDOT_CE_Configuration\Organization\CivilWorksetSeed" Set rv = sh.BrowseForFolder(WINDOW_HANDLE, strPrompt, intOptions) If rv Is Nothing Then WScript.Quit Else prjRootPath = (rv.Self.Path) End If prjNum = "false" Do while prjNum = "false" prjNum = InputBox("Enter the project:","Project number","1234" ) prjDestFolder = (prjRootPath & prjNum) prjCfgFile = (worksetCfgDir & "\" & prjNum & ".cfg") If IsEmpty (prjNum) Then WScript.Quit ElseIf fso.FolderExists(prjDestFolder) Then msg = "Project directory " & prjDestFolder & " already exists." If fso.FileExists (prjCfgFile) Then msg = msg & vbCrLf & "Project file " & prjCfgFile & " already exists." title = "Working" End If MsgBox msg, 0, title prjNum = "false" ElseIf fso.FileExists (prjCfgFile) Then msg = "Project file " & prjCfgFile & " already exists." title = "Working" MsgBox msg, 0, title prjNum = "false" End If Loop strPrompt = "What is your seed Project?" intOptions = BIF_RETURNONLYFSDIRS + BIF_EDITBOX + BIF_NONEWFOLDER rv = False Do While rv = False Set rv = sh.BrowseForFolder(WINDOW_HANDLE, strPrompt, intOptions, wsSeedRoots) If rv Is Nothing Then WScript.Quit ElseIf StrComp (rv.self.path, wsSeedRoot, 1) = 0 Then msg = "You must choose a sub directory!" & vbCrLf & rv.self.path & vbCrLf & wsSeedRoot title = "Worked" MsgBox msg, 0, title rv = False ElseIf Not fso.FileExists (rv.self.path & ".cfg") Then msg = "Seed configuration file " & rv.self.path & ".cfg" & " does not exist." title = "Error" MsgBox msg, 0, title rv = False ElseIf Not fso.FileExists (rv.self.path & "\" & rv & ".dgnws") Then msg = "Seed DGNws file " & rv.self.path & "\" & rv & ".dgnws" & " does not exist. Contact CADD support!" title = "Error" MsgBox msg, 0, title rv = False Else wsSeedDir = (rv.Self.Path) wsSeedFile = (rv & ".cfg") wsSeedDGNws = (rv & ".DGNws") End If Loop fso.CopyFolder wsSeedDir, prjDestFolder If fso.FolderExists (prjDestFolder) Then msg = "Project directory created " & prjDestFolder fso.MoveFile prjDestFolder & "\" & wsSeedDGNws, prjDestFolder & "\" & prjNum &".DGNws" If fso.FileExists (prjDestFolder & "\" & prjNum &".DGNws") Then msg = msg & vbCrLf & "DGNws file " & prjDestFolder & "\" & prjNum &".DGNws" & " was created!" End If End If Set objFile = FSO.OpenTextFile(wsSeedDir & ".cfg", ForReading) strText = objFile.ReadAll objFile.Close arrLines = Split(strText, vbNewLine) rem2 = "# Configuration file " & prjNum & ".cfg" newText = ("_USTN_WORKSETROOT = " & prjRootPath & "$(_USTN_WORKSETNAME)/") Set objFile = fso.CreateTextFile(prjCfgFile, ForWriting, True) compText = Replace (rem1 & vbCrLf & rem2 & vbCrLf & rem3 & vbCrLf & rem1 & vbCrLf & newText & vbCrLf,"\", "/") objFile.WriteLine compText For i=0 To UBound(arrLines) If i > (iNumberOfLinesToDelete - 1) Then objFile.WriteLine arrLines(i) End If Next objFile.Close If fso.FileExists (prjCfgFile) Then msg = msg & vbCrLf & "Project file created " & prjCfgFile End If msg = msg & vbCrLf & vbCrLf & "Your Project " & prjNum & " was created successfully! " title = "Worked" MsgBox msg, 0, title WScript.Quit
HTH,
~HTH
John.
yep
Ok. This would make a big difference for us so I hope the change comes rather quick.
Thanks!
Thanks John!
Any news on this? Is it fixed in update 7?
