_USTN_LOCALE_LANGUAGE is a predefined and locked variable. According to recommendations I'm using this var to set some configuration issues.
Now I have computers on which my config does not work as the variable points to 'de', although the application is started in english (en) (and no language pack is installed anymore, either).
Where does MicroStation draw the language from? I can't find _USTN_LOCALE_LANGUAGE set (as a definition) anywhere in the config, only as a reference.
I don't know exactly at what you're hinting at. I never refered to Upgrades. In my first post I mentioned that the german LP is currently not installed but the variable nevertheless Points to 'de'.
But as a matter of fact, yes, we do not use the german full download, we use the std. english download and use a language pack usually.
Can someone at Bentley please just look into the Code and determine how the value for this variable is build?
This issue happened now longer ago, I'll have to look again into the matter. Also if this is related to the omnious file msdefaultlanguage.txt which MicroStation creates in the prefs (and which cannot be predefined administratively).
Rob.G said:Where does MicroStation draw the language from? I can't find _USTN_LOCALE_LANGUAGE set (as a definition) anywhere in the config, only as a reference.
You could find the variable after creating _ustn_displayallcfgvars = 1 in your Configuration Variables dialog box. That variable seems to be needed for certain localized versions of MS in order to process their delivered font resource files (e.g. MS_SYMBRSRC).
For the selection of language, you could have access Preferences > Language > Select Language after installing the language pack.
I know that. I know where to find the variable visually in the configuration dialog. My question was where MS CE creates the variable. it is not part of the configuration, you won't find it in any cfg.
I also know that you can change the language of the MS GUI via preferences. This does not answer the real question though: how can _ustn_locale_language be used in a config to determine the language of MS CE. Can't it be used for that purpose. Obviously I have difficulties.
As a workaround I use this construct:
%if $(_USTN_LOCALE_COUNTRY) == "" MS_KEYBOARDSHORTCUTSSEED = $(MS_ORGANIZATION_USER_APPSETTINGS_DFLTS)KeyboardShortcutSeed_$(_USTN_LOCALE_LANGUAGE).xml MS_KEYBOARDSHORTCUTS = $(_USTN_PREFNAMEBASE).KeyboardShortcuts_$(_USTN_LOCALE_LANGUAGE).xml%endif
because I found that _ustn_locale_language is only correct if _Ustn_locale_country is not set.
So how are these 2 variables determined by Bentley?
